Hi everyoneI have just been putting together my new quad and I have finished the build and I am now at the stage of sorting out my acro naze32 in cleanflight. I have just come across a problem which I can't get my head around. Basically I have the flysky fs-i6 transmitter and reciever. The reciever supports ppm and so it is connected to the naze by a single servo wire. My naze board is new and has a slightly different pin layout. The pins for where you connected your reciever are now a long strip of single pins. The receiver is connected to the first 3 pins on the naze board. In cleanflight i have done most of the stuff. I have calibrated the motors and enabled ppm etc. the problem is that when I connect my 3s lipo to the quad through xt60 wire the LEDs on the naze do not come on. Only the LED on the reciever lights up. The transmitter does not connect to the reciever either now. I plugged the quad back into cleanflight and reseted the board and reflashed. When I try to calibrate the motors now they do not spin or anything when the lipo is plugged in.
Please if anyone could help me with this I would be very grateful. Thanks. I will leave some pictures as well. Thanks again.
