agridronedesigner
Active Member
In real-world spraying operation, productivity and cost control depend on three key factors: spraying efficiency, battery endurance, and flight stability. The EFT Z80 was recently put to the test in a fully autonomous operation to evaluate how its standard configuration performs under real operating conditions.
Test Configuration:
Battery: 18S 35Ah (fully charged)
Payload: 80L liquid
Application Rate: 3L per mu
Flight Speed: 13.8 m/s
Mode: Auto Mode
1. Field Performance Highlights
The Z80 covered 26.79 mu (approximately 1.79 hectares) on a single charge. For large-scale operations, its high-flow spraying capability ensures thorough coverage while significantly improving overall efficiency.
Here is the real test data of Z80 spraying operation:
2. Versatility & Heavy-Duty Design
Designed for heavy load agricultural applications, the Z80 is a multi-purpose platform capable of spraying, spreading, and lifting. Its high-strength metal truss frame allows stable flight under heavy load,and the drone comes with an 80L liquid tank for spraying,a 120L Tank for spreading and up to 80 kg payload for lifting operations.
The spraying system features a flexible impeller pump and four centrifugal nozzles, delivering consistent and efficient spraying across large areas.
3. Seamless Switching & “Last-Mile” Logistics
Beyond spraying, the Z80 can be quickly converted into a spreading system equipped with a high-torque auger for smooth, clog-free spreading operation. It can also switch to a lifting configuration, carrying payloads of up to 80 kg while maintaining stable flight—providing an efficient solution for “last-mile” transport in agricultural and forestry environments.
Note: Application rates may vary depending on crop type and environmental conditions (such as wind and temperature). Battery performance may also change over time with usage cycles. The test data provided is for reference only.
Check the the Video:
Test Configuration:
Payload: 80L liquid
Mode: Auto Mode
