Agricultural Drones Engineering Perspective: EFT X2800 Full-Load Testing
agridronedesigner
Payload specifications on a drone frame’s product page tend to answer one question — how much can it carry — while leaving the more useful question unaddressed: how does it actually behave once that weight is in the air? The video accompanying this post shows full-load testing on the EFT X2800 heavy-lift frame, and the numbers coming out of that test are worth unpacking in more detail than a typical spec sheet allows, because they say a lot about what this class of equipment is actually good for — and where its real operating limits sit.
Why Heavy-Lift Frames Are a Different Engineering Problem​
A large agricultural drone frame built to carry 200–300kg isn’t a scaled-up version of a standard spraying platform — it’s solving a fundamentally different structural problem. At lighter payloads, a frame mainly needs to manage vibration and maintain balance during horizontal flight. At 200kg-plus, the engineering priorities shift toward load distribution under vertical stress, motor thermal management under sustained high output, and battery configuration that can deliver enough current without adding so much weight that it erodes the payload advantage in the first place.
This is where the X2800’s dual-battery setup becomes relevant beyond just “more capacity.” Running dual 70Ah batteries (28kg each) isn’t simply a matter of doubling energy storage — it’s a design decision about how to deliver sustained high current to motors under full mechanical load while keeping the total airframe weight within a range that still leaves meaningful room for actual payload. Every kilogram spent on battery is a kilogram not available for cargo, fertilizer, or spray liquid, which makes battery configuration one of the more consequential trade-offs in heavy-lift frame design.
Reading the Full-Load Test Numbers​
The test data shown in the video breaks down into two conditions, and the difference between them is instructive:
Full load (200kg mounting weight): 9 minutes 39 seconds of flight time, ending with 20% battery remaining.
Standard load: 8 minutes 33 seconds, ending with 30% battery remaining.
At first glance, it might seem odd that full load produced a longer flight time than standard load — until you account for the remaining battery percentages. The full-load test was run closer to its safety cutoff (20% remaining) than the standard-load test (30% remaining), which means the actual usable flight window under standard load, with the same safety margin applied, would come out shorter than the full-load number by itself suggests. This is a detail that’s easy to miss if you only glance at the headline flight-time figures without checking the remaining-battery context — and it’s exactly the kind of detail that matters when planning real mission windows rather than best-case marketing numbers.
The practical takeaway: operators need to plan missions around usable flight time down to a consistent safety threshold, not around the raw flight-time number reported at whatever battery percentage the test happened to stop at. A 9-minute-39-second flight sounds impressive next to 8 minutes 33 seconds, but the more useful comparison is minutes of flight time per percentage point of battery consumed under each load condition.
What This Means for Agricultural Deployment​
For farming operations evaluating a farm spray drone or considering a drone for spraying at this payload class, the real planning question isn’t “how much can it lift” — it’s “how many productive minutes do I get per battery cycle at the payload I’ll actually be running, and how does that scale across a full day’s battery rotation.”
At 200–300kg payload capacity, the X2800 sits in a category suited to large-acreage commercial farming, forestry management, and broad-acre crop protection work where the priority is moving large volumes of liquid or material across extensive terrain with fewer total flights, rather than maximizing flight duration per battery. This is a different optimization target than a lighter precision agriculture drone built around long hover time and fine application control over smaller plots. Neither approach is objectively better — they’re built for different points on the field-size and payload-volume spectrum, and matching the platform to the actual operating profile matters more than chasing the largest available payload number.
The Caveat Worth Taking Seriously​
The flight-time figures above come with an important qualifier that’s easy to skim past: results vary with weather conditions, temperature, and battery health, and the data is explicitly framed as reference-only. This isn’t boilerplate disclaimer language — battery discharge characteristics genuinely shift with ambient temperature, and a 70Ah battery pack that performs one way in mild spring conditions will behave differently in summer heat or cold-weather operation. Operators planning missions around a heavy-lift platform should treat published flight-time figures as a starting point for testing under their own field conditions, not as a guaranteed operational constant — and should build in margin beyond the tested cutoff percentages rather than flying to the edge of them.
Where Heavy-Lift Frames Fit in a Broader Fleet​
For operations building out a mixed fleet rather than relying on a single platform, an agri drone frame at this payload class typically serves a specific role — high-volume, large-area passes — rather than replacing smaller platforms entirely. This is also where a well-engineered agri frame at a lighter payload tier complements a heavy-lift platform, covering the smaller or more irregular plots that a 200kg-class frame isn’t the right tool for. Understanding the real flight-time-per-load characteristics, rather than the marketing headline numbers, is what allows an operation to correctly slot a heavy-lift frame — and the agricultural drone fleet around it — into a broader equipment mix instead of over- or under-estimating what it can realistically contribute to a day’s work.
Full test footage and load configuration details in the video above. Questions about the dual-battery setup or how the X2800 compares to other frames in EFT’s lineup — happy to discuss in the comments.
#EFTDrone #X2800 #HeavyLiftDrone #200kgPayload #DroneFrame #IndustrialDrone #UAV #droneforspraying #agriculturaldrone #precisionagriculturedrone #agridroneframe #agriframe #farmspraydrone
