Unfortunately, I did not try to power & BF it. Huge mistake on my part.
I do own a multimeter. When I power the ESC, I still get battery voltage out each motor pad. Not sure if that's good or bad.
Both ESC and FC are capable of handling battery voltage so that shouldn't be an issue for the FC.
I had battery going through ESC and then the ESC powering the FC.
Here's a a couple pictures of the wiring on my quad.
View attachment 4193 View attachment 4195
So you are supposed to flash betaflight before you begin to solder?Did you try to power it & BF it before you done any soldering through the usb?
My build consist of:Can you tell us what that fcb is & what version of holybro esc.
I think he meant to test the FC before soldering so you can narrow down what could potentially be wrong.So you are supposed to flash betaflight before you begin to solder?
Yeah I set all modes pids before I Solder anything & flash latest ware.My build consist of:
Joshua Bardwell F4 AIO
Tekko32 4in1 ESC
Hypetrain Le Drib 2306 2650 KV
TBS Unify Pro
I'll have to try this!Yeah I set all modes pids before I Solder anything & flash latest ware.
That way if it don't work after finish the build, I know it was my fault. Same with esc's. I use a £2 servo tester as I buy a few at a time & sometimes they go in a draw from weeks..
Oops. Sorry, the wiring diagram I have is what I initially did. Then I took it apart to see if I can single out the issue. Seems like the FC is completely dead. Maybe too much heat on my soldering?It's not wired up as per the diagram. Tekko32 4in1 ESC isn't getting any power, lipo needs to be connected directly to the Tekko32. It will feed the flight controller
None at all. I noticed that the bootloader button gets really hot.When you plug your flight controller into your computer with only the USB cable (no lipo) do you get any LEDs at all?
Celsius or Fahrenheit?I do most all of my soldering with the iron at 370 degrees![]()
