Ir88ed
Hello!  This will be our first quad copter build, and my son and his team plan on using the finished copter as part of a science/engineering project.
For the science project, the boys need to pick some variable to change, and then measure the effect. What we were thinking is the effect of battery weight/power on time to ascend to 100ft (not exactly sure how we will measure 100ft).
Does this sound reasonable, and are there several different compatible batteries available that could be tested? Does anyone have any other suggestions for things we could test? Basically, it would need to be something that can measured and graphed.
Reading some of the other posts in this section, I see that including a build list is common, so below is what we are thinking. Please also feel free to comment, as this is our first build and we really have no experience to rely on here.
-BW® 2 Pairs 9047/9047R Propellers Propes 9x4.7" Blades
-SKYRC iMAX B6AC V2 Dual Power (6Amps, 50Watts) Balancing Battery Charger
-Generic 10cm Male to Male Extension Lead Wire Cable for KK MWC Eagle Control Board(pack of 10pcs)
-Turnigy 9X 9Ch Transmitter w/ Module & 8ch Receiver (Mode 2) (v2 Firmware)
-Hobbypower KK2.1 LCD Flight Control Board 1.9S Firmware for Multirotor Flying Wing V-tail
-Neewer® RC Accessories Set 680g 1000KV Outrunner Brushless Motor + 30A Electric Speed Controller ESC
NEEWER® 4-Axis HJ450 Frame Airframe FlameWheel Strong Smooth KK MK MWC Quadcopter
Battery:
Lectron Pro 11.1 volt - 3000mAh 30C Upgrade Lipo with XT60 Connector for DJI Phantom
Battery:
