Cartman9090
I am new to this! What is to be checked? Armimg not reacting on stick.
Checked the orientation and the props direction, seems ok. The devil seems to be present... Other tips? Try downgrade fw?Tazmanian Devil Effect. (That's an actual betaflight term now) Board orientation wrong, motor direction wrong or props on wrong
Do all the motors turn in the motors tab if you slide the master up & lipo in.
Did you flash the esc firmware & match the end points up to match min & max in BF. The video was jerky & I'm on my phone, basic but are the tx/rx bound?
What protocol are the esc's & does it match what is checked on the configuration tab. Top right.
Are you getting input on the receiver tab in BF?. Have you set modes up properly & set the Aux switches for arming & modes on the radio Tx itself.
Do your motors move in motors tab in correct order. If so then it's settings on the fcb, if not it will be the esc's.
I forgot my old littlebee only have 1shot125 but I clicked multishot as normal & I got exactly what is happening to you now. But the few things above can cause this.
It could just be that you have to be a bit more gentle on the stick.
But in blheli you will notice there is a minimum throttle command on a slider for each esc & a maximum.
For my own reasons I have mine @
Min = 1020
Max = 1980
Then in BF config I have
Min = 1005
Mid = 1500
Max = 1980
And my mid stick is @ 50. Have you altered this on yours. If it's on or around 30 then this would have the effect you are having. Someone else had this same problem on here not so long ago. It may be worth looking @ thread post going back a month or so.
Is there such a difference on throttle minimum 988 ~ 1010?
I'll see if I find that prop!Prop's I use @ moment on that size motor
Dal cyclone V2 5040-45 tri blade
King Kong tri-blades
Emax avant dual & tri blade
I think the Dal are the best.
Im going to try some gemfan over the summer.
I calibrated esc's now, wasnt familiar with the prodedure maxing the Main motor slider and then connecting the battery. Seems like that made a difference but need wait for props. But should I do something to any software om esc's, and how do I do that?That feature you are talking about is called antitaz (protection against the Tazmanian Devil effect) I'll say it again, 99% sure it's improper board orientation. There's a tiny arrow on your flight controller, which way is it pointing?
